Wiring problems help wanted
  • 48whip
    48whip
    hey guys,
    So it was time to cut loose the original indicators on my 48.
    I got the front one working and they started blinking quicker than normal after 10 seconds or so.
    The rear ones are installed but not wired and I have side mount RSD with stop light tag bracket.
    I blew two fuses and replaced them from the local servo, now when I turn the bike on, I have nothing in the indicator department. Any help would be great or if anyone can rewire them for me that would be much appreciated.
    I'm located in hurstbridge and I can get the bike started.
    Cheers Jared.
    Not near to help, but...
    Fast blinking blinkers is the bikes way of saying you have blown a globe, or have a short, or have a bad connection, or your running LEDs (or the wrong globe) so it's not drawing enough current.
    You should have all four blinkers hooked up before trying, but the fact that you're blowing fuses means it's more than just a missing globe. So I guess your back to asking for help, unless you're planning to start from scratch and following the instructions (presuming you got some) step by step.
    I wouldn't worry about the load equaliser/s until I found out why fuses are popping, then installed all the blinkers to see if it still blinks fast.
    Of course, if you're installing LED lights you prolly will need them, unless you really like a fast flash.
