Changing stock shocks
  • Sparky666
    Sparky666
    Hi guyz,
    Brought a new iron 883.stage1 AC,super tuner,v&h short shots,flipped mirror.
    didnt bother about changing the stock shocks at the time of buy.Now when my partner want to be the pillion ,stock shock gives  kind of "SHOCKS"on some roads.So anyone have any suggestions about changing the shocks would be highly appreciated.
    i live in Adelaide.wondering the works are better at Harley heaven or is it equally good at Adelaide bike works??
    thankz for reading.any help regarding this is great.
  • darkdesign
    darkdesign
    Down there you're closeish to Ikon and YSS. Get some 12.5" shocks, put them on yourself. Then you'll want to do the front end too, as the ride will be great at the back, but still chatter at the front.
  • GT 1200
    GT 1200
    Welcome Sparky. Only heard good things about Bikeworks, so far.
    Same for YSS out near Angle Vale, I'm planning to go see them, as they have been highly recomended and are local.
    Meanwhile, check out the SA rides, hope to see you out there.
  • Nomada
    Nomada
    I went with YSS cause they are 10 minutes from home.
    Very happy with both their service and product.
  • Sparky666
    Sparky666
    Thankz guyz for the advice.will look into it soon.
