Online: B0nes
Sealing a spoked wheel
  • Wynchester
    Wynchester
    Hey guys,
    I'm running an 18x8.5 60 spoke on the back of my rocker. The wheel was supposed to be tubeless but when I got the tyre put on it leaked like a sieve.
    I'm running a tube as a short term fix but does anyone have any recommendations for sealing it up to run tubeless?
    Thanks,
    MAtt.
  • Nomada
    Nomada
    I do believe, and I have been wrong before,
    Spoked rims have a rubber rust band and a tube.
    Same reason pushbikes have tubes.........can get a seal with spokes.
  • Wynchester
    Wynchester
    The trouble is that people are telling me that
    You can't get tubes for 240/250 tyre.
    I'm running a tube for a 200 in there ATM.
    Makes the profile of the tyre a bit taller than meant to be also.
    I've seen a few eBay sealing kits but none for wide tyre.
  • Will67
    Will67
    the fat spoke wheels are meant to be tubless the one i puyt on the front of my twinkie had this black tacky shit on the inside to seal it
  • Wynchester
    Wynchester
    Couple of interesting options here....
    http://supermotojunkie.com/showthread.php?105809-Making-your-spoked-wheels-tubeless-with-pictures
    http://cyb.smugmug.com/Motorcycles/KTM/Tubeless/i-BjwM3St
    Also I didn't go with the Fat spoke mammoth thing I just got a regular laced wheel.
  • Wynchester
    Wynchester
    Well the simplest answer seems to be the best...
    drag specialties make a tube for a 250 tyre part number #ds181234
    Now I just gotta find one in oz or pay 35$ to ship a tube from the US!
