Online: GGUser731
'87 Front Wheel
  • Kuzzo
    Kuzzo
    Hey guys.......
    The '87 FXST Softail I've just bought has a 16 inch front wheel fitted and I'd like to change it back to what I believe should be a 21 inch.  Is anyone able to tell me the axle diameter for the '87?  I am looking at a 21 inch from a '12 model which has what appears to be a 1 inch axle.
    Failing that, anyone know where I might get a 21 inch wheel that will for the '87?  I'm gonna need a front fender as well, but I think that will be an easier task.
    Kuzzo
    [script removed]
    I'm an 86 and its a 3/4" axle.
    I sell New 40 Spoke 21 x 2.15 Front Wheel to suit your Bike $185.00, Metzler ME 880 Front Tyre $136.00,and a Front Fender $49.00,,, VPW 03 8405 9212
  • Kuzzo
    Kuzzo
    Here's a couple of pics of the axle and a portion of the front wheel hub
    [script removed]
    [script removed]
    [script removed]
  • Kuzzo
    Kuzzo
    [script removed]
    That's the wheel spacer , the axle runs inside it you wheel is a pre 1999 with tapered bearings . The one I offered you
