Quieting down 103 motor
  • reaver_05
    reaver_05
    Has anyone out there, found a way of quieting down the new 103 motor. I have a 2013 heritage with 3000kays, sounds like a noisy sewing machine. I've had it back to the dealer and they had a listen and said that this is how they all sound. I previous had an 2007 Dyna which didn't sound anything like this. I know they are different motors.
    I have tried different weight oils but made no difference.
    Have been told that an upgrade to better lifters and a SE high volume oil pump will quiet it down.
    Has anyone tried this update? or does anyone else know another way of quieting the motor down.
    Thanks
  • Ando
    Ando
    New lifters and adjustable pushrods
  • Kato
    Kato
    Dont get me wrong here but if you are riding with a helmet on its that bloody loud that you cannot hear the motor (Noisy or otherwise) i would have thiought
    I assume you are referring to it when the bikes at idle and you have your helmet off ?
  • reaver_05
    reaver_05
    You can still hear noise when on bike with helmet on. The noise comes more from the top of the motor. It's more like a sewing machine whir.
    I didn't think there'd be much of a difference between the noise of the 96 and 103 top end of the motors, although I know they changed the lifters about three times and the second lot were the best, most reliable and longest lasting
    I do.....I can swap you an 883 Sporty Motor for your loud and horrid 103! The Sporty one is very quiet....
  • Retroman
    As said , "that's just the way they are mate"
    The "balanced" motors have more mechanical complexity than the Dyna/Tourer motors of course.
    Within every manufacturers range there will be quieter/noisier motors
    Maybe yours is at the "noisier end of acceptable"
    On my CVO's the motors are noisy , but the straight thru' pipes are NOISIER.
    You've reported it so keep monitoring it !
