2014 Breakour pillion seat
  • goldiedg
    goldiedg
    Hi all,
    Just picked up my 2015 Breakout...couldnt be happier. The only thing is the pillion seat is really bad for anymore than say 15mins ride. The seat as you guys probably know is very low and has almost no cushion.
    Any ideas of maybe a trimmer in Melbourne to re make the pillion seat or do a replacement rider/pillion set up?
    Cheers Davd
    ps sorry for the subject line should read (2015 Breakout pillion seat)
  • T-1000
    T-1000
    Howdy
    If u want something that's gonna be to ur taste and liking then u will need to find someone to make one up for ya. I have a Danny Gray butt crack solo for iup and then throw on the original for 2 up....luckily my missus has a small butt therefore not a problem.....otherwise you can go for the suction cup stick-on they appear to be wide enough to be okay, pricey for wot it is.
    Good luck let us know if u find sumthin might be interested.
  • Nomada
    Nomada
    I don't know if anyone is making seats for the 2015 yet.
    Short term fix try a gel or Airhawk seat cover.
  • BradndAlly
    BradndAlly
    Hey Goldie,
    Got the missus a Sundowner Pillion seat. She thinks its very comfortable for what it is.
    Hope this helps...
  • 3DDevil
    3DDevil
    Hey BradndAlly,
    Can you use the Sundowner Pillion seat with the stock seat? Thanks...
