snap on torque computer
  • mick44
    mick44
    Just out of curiosity.
    Has anyone got the snap on torque computer No SS-306G, and snap on adaptor No SRES24
    Want to remove softail rear shocks and if anyones got the torque comp, could you place a pic up and value for 130 ft-Ibs and 35 ft-Ibs.
    Have rang snap-on about the torque comp which is just a sliding plastic ruler type thingy, but snap on seem to be having trouble finding it. Snap on Australia.
    Or is there another torque computer alternative when using an adaptor other than tighening shock bolts as tight as you can.
    Cheers for any info
  • mick44
    mick44
    Thanks for that Speedzter. Appreciate it.
