Online: skirtster
Sportster 1200 Oil Leak from Crankcase
  • FuntCase
    FuntCase
    I have a 2010 sportster forty eight with 25 000 km and have noticed oil below the starter motor.
    It is a slow buildup and thought it was from the breather but ok, then read and thought it was the seal between the two halves which can be a nightmare and big $$$.
    Looks like its not that but looking from the left hand side below the starter motor there is a sensor which enters the reverse side sort of opposite and higher than the derby cover.
    Can anyone please tell me what this sensor is and can it be tightened ?
    I canot find any thing in the service manual I downloaded ?
    i think your looking @ the speedo censor , wash proper & blow dry when puff babypodwer all round the area then ride around the block  then look for the wet spot  , could be gearbox overflow tube
  • Nomada
    Nomada
    Good advice,
    I did that with a fat chick.....baby powder to find the wet spot.
    worked a treat.......
    did you lick the powder off the wet spot 1st
