Online: OlChesnut
breakout accessories
  • liamstar
    liamstar
    Hi just after a few ideas for my new breakout. How much has everyone paid for the blackline dash conversion?
    License plate options other than the chopzilla kit?
    And also deciding between matching arlen ness or performance machine sets of grips, pegs, mirrors, shifter and brake pedals? What other companies make matching sets? As I dont want to turn the bike into too much of a standard bolt on bike?
    Thanks for.any input.
  • T-1000
    T-1000
    G'day Liamstar,
    You have sum deciding to do with the accessories ....... but as for the rear numba plate..... I relocated my plate after no response from that KPR mob and the price was too much for my liking for what they charge her in Syd.
    1.Take the plate off
    2.cut the two bottom tabs off
    3.take of xistn numba plate light
    4.align the bottom off the numba plate with the bottom of the guard and drill holes for screws or go higher if u wish .
    5.get ur self sum numba plate leds from ebay and rewire..... wham ooooo
    You just saved ur self sum cash for other shit to do ....it might not be clean enuff for ur liking but hey ......
    Sorry no pics of steps or finished product .....not too many on the forum with Breakouts....
