Online: B0nes
Rear blinker bulb specs 09 Street bob
    Noticed one of my bulbs is dim and blinking fast so I dropped into a servo or two (nothing else was open) trying for a replacment, but nothing doing.
    My bulb says 12v32/30CP +B...yeah, good luck with that.
    I phoned a friend and he said the packet should say #1156, but he's a yank and prolly reading off the manual anyway.  So what's the right specs for a rear blinker bulb on a 09 Streetbob?
  • Big Steve
    Big Steve
    I have never found them at servos, the pins are in different spots on car bulbs. I stocked up on a few from the dealer at a few bucks each.
    Two hour ride for the closest dealer. I might try supercheap and autobahn.
    Well that's interesting Allde, I'm sure I looked at a set of P21w's, but the little tab thingys that hold the bulb in weren't staggered, high/low. Or maybe I didn't look at that packet?
    Cheers guys.
    Just FYI. I went and bought a bulb today (for the commodore) and decided I'd stick it in the bike and see it if would fit. Sure enough, it does and works perfectly . The "tabs/prongs" are level and it makes no difference - it actually fitted better than the idiotic bulbs that were in it.
