Online: John.R
right hand indercator
  • iwillhaveacrack
    iwillhaveacrack
    hey lads i am in need of some help,
    changed the bars over last night (internal wiring) and the right hand indercator now is not working, it worked all day while i was out and about but on the way home it gave up....the red key is also now staying on..and yes i thought it was an earth fault so tonight i removed the right side wiring from the bars and checked for rub throughs but none are present, i also checked inside the throttle housing for loose connections and none were found. i also resolderd all connections.
    and now here i am asking for some direction
  • iwillhaveacrack
    iwillhaveacrack
    found the issue, rub through rear right indicator....just happened to show its self when I changed the bars just to keep it interesting.
