Online: John.R
unknown plugs on my Roady
  • gidgi
    gidgi
    Hi can anyone tell me what the two plugs are for, beneath the fuse box behind the left sidecover, one has a rubber end cap the other has a hard plastic sleeve cover on it.I have tested the one with the rubber cap that works only with ignition on not Acc it only has 3 wires I wish to use this for my Aux power but don`t know the Amp rating I have been told about the toggle switch behind left side of narcell controling a plug which is under the seat but that particular plug dont seem to do anything, can someone shed some light on this. much appreciated
  • Retroman
    Rubber endcap doodad is your Deutsch connector for the ECM access , either for the dealer Digitech workshop laptop OR your own tuner dongle
    DON'T TRY TO DRAW POWER FROM THERE !!
    I'd have to see a photo of the other plug as I don't have a Dresser myself , but I have worked on plenty Re the ECM re-tuning
  • gidgi
    gidgi
    thank you retroman I suspected one of them would have been for sert much appreciated. I wouldn`t have cut or changed anything until positive.
    I will investigate further cheers mate
  • Damo222
    Damo222
    I was under the impression that there is a connection for a trickle charger.
  • Damo222
    Damo222
    What i meant was if you buy a trickle charger that may be the plug you need to plug it into.
