Online: John.R, Hilly
will the night dragons fit?
  • sparky89
    sparky89
    Hi guys,
    I'm looking to upgrade the rear stock 160 scorcher tyre to a 180 on my 2014 street bob special edition, does anyone know if the pirelli night dragons will fit straight on or are the scorchers the only brand that will fit the 180 straight on? cheers
  • tommygun
    tommygun
    pirelli night dragons go straight on.
    180/60/17
    there are heaps of options if you go a 180/55/17 because that is what they run on sports bikes but your speedo will be out and it will lower your bike slightly.
  • sparky89
    sparky89
    ok so the pirelli night dragon 180/60/17 75V tyre can be a straight replacement for the stock scorcher 160/70/17 73V?
  • robots
    robots
    Hi,
    Yeah fit on but they not a wide looking tyre and probably 170mm once fitted
    Thanks
    Robot
  • tommygun
    tommygun
    its pretty fucked but its booked in tomorrow for a new one.
    this is how they look fitted though
  • tommygun
    tommygun
    not really. its 2cm...
    i like it. still handles mint.
    it really comes down to how the tyre wears due to the rides your doing
