Online: B0nes
Clutch Squeal in 2012 Ultra CVO FLHTCUSE7
  • Lanoseal
    Lanoseal
    Hi
    I havw a 2012 Ultra CVO FLHTCUSE7 done about 8K.  I have developed a squeal from the clutch when disengaging, I have heard that this is not uncommon in CVO's. Has anyone heard of this or had any experiece with this issue?
  • HogBag
    HogBag
    Sounds like a inner clutch,primary bearing might need replacing.
  • Lanoseal
    Lanoseal
    Pulled clutch pack out last night and found the 3 discs closest the gearbox were dry. Soak them in ATF for a couple of hours and reinstalled. No slippage or squeal, clutch is noticeably smoother in operation.
    Dave
  • Wimbo
    Wimbo
    Well thats allright Ahhh.
  • Lanoseal
    Lanoseal
    Also I have changed the oil in Primary over to Synthetic ATF (Dexron 4&5) has anyone had any negitive results with using atf?
    Not yet. I use Valvoline ATF type F. All good so far on 2012 ultra.
