120r motor in a2013 H.D. Breakout
  • Kevin Wellman
    Kevin Wellman
    I have a 120r crate motor in a breakout .Its been remaped(super tuner) 9 times over 11months,been on the dyno,has had new plugs,new leads,new coil,new throttle body,new injectors and it still missing and farting and generally running like a pig at mid throttle in 1st ,2nd, 3rd&4th   .At 60km/Hr at mid throttle in 3rd gear ,it is at it,s wourst. It is continously blacking the back plug. Any help out there.
    Where are you located? Was the motor installed by a dealer?
  • Ando
    Ando
    Fouling the plugs up by the sounds of it.
    is it Fuel fouling them up or oil?
    Comp and leak down test, go from there
  • Ando
    Ando
    oh and welcome to the forum
  • 22
    22
    Hi Kevin, where did you get the motor from and what $ did you pay for just the motor?
    Am looking at putting one in my breakout.
  • 98fxstc
    98fxstc
    Oops
    Doesn't matter
    Should have checked the date on the original post
    and it doesn't look like he's been back
