FLHS 1993 lighting help
  • jonatyre
    jonatyre
    Hi I have a 1993 FLHS and have removed the front spotlight/blinker bar I was hoping to get something that mounts in the same holes on the front. I have looked at Kuryakn/ jp cycles and they list a front but only for a later model. Has anyone changed these before I am thinking that the mounts dont change but maybe the wiring is different. The tech help guys just say they wont fit but im not sure why.
    thanks in advance
  • HogBag
    HogBag
    I have a 2007 electra glide and removed the light bar and used the bottom light bar bolt holes to mount late model bullet type blinkers. I used allen head high tensile type bolts with a thread cut into them to suit the bullet type signals. I can run the light bar with the bullet type blinkers or take the light bar off and still run the bullet type. With the light bar mounted but stock style blinkers removed I used 1/2 inch copper pipe painted silver with chrome dome nuts to cover the spotlight springs.
    Hope this helps
  • jonatyre
    jonatyre
    Cheers Hogbag I was only thinking last night to do the same thing, I don't have any custom bike shops in my town so just wanted to make sure the bolt holes were the same distance apart.
