sportster derby cover bolts
  • Lamplighter
    Lamplighter
    Gidday from Lamplighter, what tool do I use to remove derby cover bolts on a 2006 sportster 1200 custom, the heads look different to anything I've seen.What size are these as I intend to replace them with chrome spike bolts x6, anyone know where I can buy these for my sportster? The bolt size board at bunnings worked perfectly to size my air cleaner insert bolts, thanks again for the tip, cheers.
    It's a torx bit. Get a good set - kingchrome or better. You might need an impact driver to remove the fuckers, which supercheap auto usually has the cheapest - $15ish the last time I got one.
  • Lamplighter
    Lamplighter
    Thanks Bonkerz back to bunnings & supercheap for me, love the adventure of customising! Cheers, Lamplighter
    No problem.
    Sorry to state the obvious, but in this case I mean a socket torx set, if you're going with the impact driver. Having the key ones doesn't help with an impact driver :)
    You might need one of those sockets that allows you to put on different size sockets too.
    A breaker bar works well too (less likely to slip because you only use minimal pressure) as long as you fit the torx bit in snugly.
  • beaglebasher
    beaglebasher
    why would you need an impact driver on derby cover bolts Bonkerz? are you a bit limp wristed?
    Nope. I've had several slip and fuck the head, probably because I'm the opposite of limp wristed. And of course, because I'm as stubborn as a mule and dumb as a hammer I held it on and turned it stripping them completely because they are made of shit. On a recent bike I managed to tear the fucking head off the crap because some dumbshit used red loctite and I was too lazy to grab the impact driver. So I had to drill out the hole and retap . I fucking hate all torx heads, even the ones made of decent metal.
  • Lamplighter
    Lamplighter
    Thanks for the update on the socket torx set etc....cheers Lamplighter
