Torx set
  • Neale
    Neale
    I'd appreciate it if I could get some advice on what brand of a Torx set to buy.
    Kinchrome or Snapon...they are not the cheapest but will last a lifetime and have good garantee's
  • Neale
    Neale
    Thanks.
  • tavistock1961
    tavistock1961
    I have a set of kingchrome, snapon would be good, buy the best you can afford
  • Lushy
    Lushy
    I had a bad run with snap on(SNAP OFF!!) Torx bits breaking.Try getting one out of the head bolt in a Speed Triple......... Faaarck. Got a set of TENG. Made in china Yup. I wore some of them out an just got a new set after three years. They are good.
  • Rocky2010
    Rocky2010
    I have Kingchrome and they work well, make sure when you get them you get the ones with out the hole in the centre as they could snap.
  • chopa
    chopa
    I got a set of kinchrome impact ones. They haven't broke yet
  • Hallze
    Hallze
    I had an apprentice that bought a Teng breaker bar once. I know why they called them "Teng" after he was undoing head bolts one time. When they break that's exactly the noise they make! "TENG"!!
  • mick44
    mick44
    Torx bit hint.
    Most torx bits, thats socket torx bits, have a fairly sharp edge between the bottom and side edge of the bit.
    That edge will easily chew the chrome on the inside of chrome torx bolt heads and rust quicky appears in the bolt head
    Particularly if you torque chrome torx bolts.
    Not as obvious in non chrome bolt heads but the sharp edge will chew them too.
    If you got a dremel, fit the tiny sanding disk and lightly sand the torx bit bottom edge so its not so sharp.
    If yopu have chewed off the chrome on the inside of chrome torx bolts, buy an el cheapo spray can of chrome paint, spray a bit on the end of a matchstick and rub a bit inside the bolt head and you wont notice the rust.
    Particulaly usefull if fitting accessories that contain chrome torx bolts.
    Ive not seen any brand where the bottom edge is not sharpish.
    If the torx bit is still a bit sharp, wrap electrical tape around the bottom and side edge of the bit and gently tap the bit into the bolt head using a nylon faced hammer, Helps save the chrome
