Online: B0nes
brakes grrrr fxrs
  • 666
    666
    Ok so started the repairs (long list)on the 92 fxrs rear brakes fiirst,new rotor,rear caliper kit and new pads and new dot 5 fluid what a mission to bleed 3 hours and only got a small bit of pedal any body got any ideas? ive test ridden it and it stops but it is a long way to push down
  • Steve L
    Steve L
    easy fix mate, just use the front brakes :). You obviously still have air in there, maybe try the fix some do for the front when having the same problem. For the front you cable tie the lever in and leave over night and that seems to push the air down. See if you can do simular to the rear lever, if not just sit on it all night with your foot on the brake lol.
    My FXDB has fucked rears too. I keep meaning to get around to trying to fix the pieces of shit.
  • Arron
    Arron
    I just had a quick look at my bike and checked the manual , they specifiy DOT4.
    DOT5 is silicone-based and DOT4 is polyglycol ether-based.
    Also had a look on the net and mixing DOT4 & DOT5 is a no no.
    http://en.wikipedia.org/wiki/DOT_5
    I have my 2013 Street bob booked in to have the front brake looked at , near on pulls into the bars when braking gently on the ride home from work.
  • 666
    666
    lol steve, yeah arron mine specifys dot 5
  • Retroman
    DOT 5 ONLY until and including 2005
    DOT 4 ONLY from 2006 until present date
    Early 90's bikes only had single piston sliding calipers , have to copper lube all the slider components at every pad change
    "Quality" pads are a must . Lyndall / EBC etc etc
    Stock OEM pads are actually OK as well
    Bleeding can be helped with a hand held vacuum pump system as the rear master cylinder sits low compared to the caliper , especially when compared to the front brake.
    I also clean the disc surface with thinners or similar ( watch the paint FFsake !)
    Love the DOT 5 stuff.... lasts forever!
    You could drop the caliper off the bike so it sits lower than the master cylinder (just place the old rotor in it to keep it happy as you bleed things); which should allow the air bubbles to rise upwards and out.
  • The Doctor
    The Doctor
    vaccum pump works every time $50 from repco
    If you ever find a 'Mityvac' going cheap; grab it! I have one and its a godsend for bleeding brakes as it comes with all the jars and hoses for just such a job.
  • 666
    666
    hey dave its mounted on the top,i just bought a hand off pump off ebay, so when you hold down the brake pedal is it all the way down?i just dont get it i pumped a whole bottle of fluid through it over 2 days and nothing,
  • 666
    666
    Sorted bought a pump bleeder off eBay 4 mins done just have to road test them,fronts next left side just binding a touch thoughts?
  • Retroman
    Strip the caliper sliding bolts and lightly sand all sliders , clean with CRC and lube with copper grease
  • 666
    666
    that sounds like the plan may as well do both sides hey
  • 666
    666
    Ahh just test rode it backs were working then locked up cracked the nipple and rode it home wtf is going on?????
  • bobby bob
    bobby bob
    you should also put a kit through the brake cyclinder.
  • 666
    666
    ha think i have found the culprit
    all this crude was between the cylinder and outer plastic cover inturn blocking the breather hole
    wow, never seen that before!
  • 666
    666
    well success nice solid pedal no jamming up stoked onto the next thing
