Exhaust Screws
  • Skippy76
    Skippy76
    Hi guys,
    need to know how hard it is to replace the exhaust screws ( on the cylnder head ) as i have one that is all stuffed up due to a nut not going back on correctly
    any help would be appreciated
  • Sniffenabout
    Sniffenabout
    You might need to use an ezi-out to remove the stud. not sure if this should be done with the engine stone cold or a little warm.
  • Independant_84
    Independant_84
    If there is enough stud left i would weld a nut on then undo it.
