Online: Stuart
Deadspot?
  • Kustomtown
    Kustomtown
    Hey, I've got a 2013 RK. When I down shift and give the throttle a rev, I'm feeling a deadspot i.e. no rev...sorta like a miss. This is the only time it does it, otherwise it runs well.
    The bike has stage 1...all Vance & HInes.... air intake, fuel mgmnt and true duals.
    Any help appreciated.
  • Ohio HD
    Ohio HD
    Depending on what your fuel manament is, you may need to adjust out the flat spot when cracking the throttle. My guess would be it's lean.
    ................*********************........................out numbered.
  • Jayman6
    Jayman6
    I used to have this problem on a carburetted bike that had a rubber intake manifold, the manifold perished and cracked and sucked in air. So yeah, simple answer, your running lean.
  • Kustomtown
    Kustomtown
    Cheers you blokes. Thumbs up
