Online: Retroman
Front right turning signal not working!!!
  • Clicksta883
    Clicksta883
    Hey guys,
                Bike: 2013 iron 883
               Just recently did a tank lift and wire tuck on my bike. Now my front right indicator light is not working. Both front and rear turning signals on the left hand side are working perfectly fine. On the right hand side, the rear indicator works but is blinking fast and the front right signal is not working. fuses appear to be fine. No signs of tears or kinks in the indicator wiring. I did try 2 new bulbs (but the only available ones were v12w10 compared to the original  v12w24 bulb) and they didnt work.
    Has anyone had similar problems or have a solution?
    Mine did that, but two wires were touching.
