Online: Retroman
Power vision help needed pls
  • Streetbob06
    Streetbob06
    Hi all,if just received my power vision,after updating software I am now trying to send a tune to my power vision that I've received via email,I can get the tune onto my winpv program but I'm having trouble sending it from there to the povervision itself.any ideas would be much appreciated.
  • brash
    brash
    Connect the PV to the bike
    make sure the run switch is on, don't start the bike
    pair the PV to the bike if you already havn't.
    Follow this video to load a custom tune, but hit "custom tunes" instead of the pre-configured tunes. Find the tune, load it onto the bike.
    https://www.youtube.com/watch?v=TBIZUkz-DdU
    Once the tune is loaded, follow the prompts and you are done
    rip a skid
  • Streetbob06
    Streetbob06
    Brash,the part I'm having trouble with is getting the pvt file from email stored into the power vision,I'm thinking the custom tune has to be in a slot 1 to 5 before I plug it into my bike,or do I have to pair it to the bike first ? Thanks
  • gidgi
    gidgi
    just a thought & I could be wrong send the file from email to an external hard drive maybe a USB drive of some sort, then down load into your power vision program, again could be way off ...
  • carbon fibre
    carbon fibre
    once you have the .pvt file open in WinPv, grab the mini usb cable and PV and hook it into your computer, in the winpv software there is a a tab to 'send tune to PV", click this, pick a slot and then hit send. tune will now be stored in the Pv. unplug from comp and go flash ya bike with it.
  • Streetbob06
    Streetbob06
    I'm still having the same trouble guys, I can get the pvt.file to winPV but the send tune button doesn't highlight to send through. This is windows 8 if that helps also my computer does  not recognise the pvt file it says "how do you want to open this type of file(.pvt)" - look for a app in the store.?
  • Streetbob06
    Streetbob06
    Thanks lucifer,your a legend,that notepad thing done the trick,I've now got it in slot 6 in my power vision.
  • Streetbob06
    Streetbob06
    Nah I'm pretty sure It was the notepad that helped cause as soon as we opened it with that and saved it the send tune button highlighted and off it sent.
