1968 Harley Davidson FLST EVO vibration fix?
  • tonycap
    tonycap
    Hi everyone.
    I have a 1986 Harkey Davidson FLST and I know that the Evo's have an issue with vibration due to the way the engine is mounted to the frame but I was wondering if there is anything available to try and minimise the bike vibration.
    Its OK at low speeds but once you get to about 70k/mh it starts up and it's a little difficult on long rides.
    Any advice would be greatly appreciated.
    Thanks Tony
  • tonycap
    tonycap
    sorry that should have been 1986 Harley Davidson FLST.
  • bobby bob
    bobby bob
    but still not a softail.
    why is it not ?
  • tonycap
    tonycap
    Its a Heritage Softail.
    yep I know , don't know about bobby though
    as for vibes  keep the revs between 2500 to  2800rpm and dont lug it thats the evo sweet spot ,and iso grips but u have them
    gel gloves , iso foot pegs  not sure what you would do with boards though
  • Wimbo
    Wimbo
    Hmm, My Softy vibrates more at low speeds, sure it isnt all the gear that you have on it thats causing the vibration?
  • tonycap
    tonycap
    Yes all the engine and transmission mounting bolts are secure.
    When a say "vibrating" I dont been rattling but more like after a long ride your hands and butt feel numb..
  • TJU
    TJU
    I might be wrong but I think it just comes with the territory TonyCap ... I know exactly what you mean , not so much a bad vibration but a fairly constant buzz through your hands up in the higher speeds .
    My 99 Springer is the same and real noticeable when getting off my 08 Fsxtc and then going for a blast on the 99 ... I just figured it was normal as the Evo`s are solid mounted unlike the modern Softails that have the counter balancers built into the motors and the Dyna`s of course are rubber mounted .
    Hey Perth hog what do these gel gloves look like ... are they pretty bulky .
  • bobby bob
    bobby bob
    lottsa things to look at re vibration, check pivot bushes on swing arm , primary set up , ect , ect.
  • Independant_84
    Independant_84
    I just spotted these and wonder if anyone here has used them with success.
    http://www.balancemasters.com/hotbikespread.html
