Online: Stuart
Interchangeability of cams between tc 88 and 96 motors
    Hi
    I know the top ends are very similar but the bottom ends are different between the tc 88 and 96 engines. My question is are cams fitted to a tc88 or 95 interchangeable for a tc 96 or 103? I'm looking at a pair of se204 cams currently fitted to a tc95 and want to know for certain if they'll suit my tc96 or if there are different versions of the same cam model.
    Thanks.
  • dynoharley
    dynoharley
    I have crane cams similar specs to 204 se , these will fit 96 cub and in box new , pm for price if you like ,
    Thanks very much gents.
    Dyno harley, pm sent
