My Project
  • DUGE
    DUGE
    Hi
    I got myself a project, 92 Heritage, it will take a while.
    Be good if there was a dedicated section in the forum to have "projects".
    So we could share idea's, source's etc, and put progress pic's.
    Any way, I'm going for a retro look, see how it pans out,,,, get it,,,, did ya... ya know pan.....neva mind.
    Heres a pic of the bike, and what inspires it.
    Wouldn't mind some advise, Think China's Duo-Glide replica is cool.
    Cheers Duge
    Your on your way , it's got a tool box
    I shouldn't be mean , your got a great bike to start with, I can hook you up with most of the stuff to replicate that bike give me a call VPW 03 84059212 Ian
  • DUGE
    DUGE
    Not mean, as you say its a start, one on the uder side too.
    Just taking off the back seat an rack is in the right direction.
    Pretty much what HD was aiming at when they made it, so not realy a strech.
    Thanks for the coment anyway.
    Gota start some where.
    Cheers Duge
  • Big Steve
    Big Steve
    A sub forum for projects would be great.
    You're on your way though with a a great canvas.
    If you strip everything back (Saddle bags, screen, crash bars, rack etc) you'll be half way there.
    Like i said I can help you out with the Parts needed, I stock the Shinko Tyre same as on the Orange Bike and China's Bike $167.00 each, I sell 13" Wide Solo Seat for $55.00 , Rear Ridged Pan Fender $295.00, I dont have the Header Pipe but I do have a Cocktail Muffler $75.00, I do the round Air Cleaner $55.00, I can give you a Bee Hive Tail Light for that same Price, Your Bike has the right Bars and Front End , Headlight and Front Fender as the Orange Bike, Custom Chrome made a Pan Rocker Box Cover to bolt on to your EVO Heads, yur can get the though Rollies.One of my customers has them on his Softail and there cool
    [URL=http://s258.photobucket.com/user/raced86/media/10606496_10203801846079463_2978995802105240102_n_zpsb6d16269.jpg.html][/URL]
    [URL=http://s258.photobucket.com/user/raced86/media/download24_zpsf56eb634.jpg.html][/URL]
  • DUGE
    DUGE
    Hi Guys
    Thanks for the advise.
    Yeah those pan covers look great, so does that air filter, is it the same as you got on your Blue Bobber? Had a look at your site are you talking about the filter with the holes on the front? Will the beehive light cover the hole from the ome light?
    So China those Shinko Tyres Grip good? They certainly look the part. Did you keep the Switchback?
    Thanks heaps, Duge
