Online: Ronmac
New Tool Bag..
  • Moondog
    Moondog
    Hey guys...
    Just bought this great tool bag for my FatBob. See it here.. http://van-dutch.com.au/product/tool-bag/
    The best quality I have seen...
  • bobby bob
    bobby bob
    will a laptop fit in that? or is an Iphone a better tool for Harley.
  • rodrocket
    rodrocket
    Where are they located at as I am looking for somebody to make a swing arm bag for my ride
    regards
    Rod
  • Sparra
    Sparra
    For $175.00 you would expect them to be nothing less than excellent...
    yeah, whats with everybody advertising leather in the titles, and the you read in the smallprint it is actually PU leather, which is still not leather but polyurethane only. FFs PU has its place but it's not leather at all so should not be advertised as such. Scammers.
    BTW This one looks the goods.
  • ballistic
    ballistic
    Give Steve at Kazz-Mazz ( Kelmscott ,WA ) a bell , only uses top quality real leather ... made mine and my Kimberly vest ( which actually offers some protection ,rather than the for show ones Harley flogs )
    Here is a tip for the tool rolls --if you cut down a piece of 90 or 100mm PVC stormwater pipe and fit it snuggly inside, it will work a treat keping its shape and allow you to attach it with zip locks instead of straps .
  • ballistic
    ballistic
    Van Dutch , mate Steve only uses top quality well oiled 5mm supple Buffallo leather . His products have stood the test of time and weather as he has been supplying quality to Aussie bikers for many years . As with all quality leather designed for outdoor use , it needs to be regularly oiled to last . I have owned quiet a few Aussie made stock saddles and saddlery as well as bike gear over the years and wouldn't go past the stuff Kazzmazz produces .
    My tip was mainly about how to have your supple well oiled tool bag keep perfect shape even after years of use at high speed and long trips in all weather . Also enables it to be firmly fixed without flapping about over time or at high speed . Mine has done over 30,000 ks and looks as good as the day I fitted it .
    Its only a tip ,,,can take it or leave it .
    I see you have a website and have produced A tool bag ,,,and are working on making A saddle bag down the track ,,,good for you . Best of luck with your new venture . I'm sure Kazzmazz also has a website , might be worth a look .
    The one in your pics look very nice and shiny and going by the un-weathered white cut marks on the side bags straps also brand new ..,,wouldn't mind seeing some pics of them after they have had some years of use
  • ballistic
    ballistic
    Van Dutch   Well why in your pics of battery bag etc do you state that it is made of 2.5mm American Bison ?
    Also mate who's bike is that in your pics, yours or "Moondogs " bike cause looks like the same bike to me . Are you guys sharing the bike there in Canberra ?
    and Moondog when you say you have just purchased this new tool bag , is it not the same one on your bike in pics you posted in June of 2013 ?
  • Wimbo
    Wimbo
    Well ,that went far.
  • James123
    James123
    VanDutch provides lifetime warranty against defective materials and workmanship, a perfect tool bag with the adjustable carrying style and good quality
  • ballistic
    ballistic
    'sof spammer
  • keith
    keith
    A mate has just bought this bag from Kazzmazz $55.00,looks good,and fits well.
  • Sparra
    Sparra
    Does it have the flaps that come in over the tools before the top is closed down??? I have a tool bag that doesn't and the tools have a habit of slipping out and bouncing up the road...
  • keith
    keith
    No that's it no inner flap, I'm sure to here about it if its a issue.
