Online: John.R, Stuart
What is the best way to ride the first 1000ks?
  • blubarb
    blubarb
    What is the go with riding the Sporty for the first 1000ks - lots of speed variation?  I've heard that you can "glaze" a cylinder by keeping it underpowered. What is the best approach so not as to damage valves, etc..
    Hard , ride it Hard
  • jim76
    jim76
    ride as nomal dont let it idle for extened time n use the rev range but dont wring its neck to much. n dont larber it in to higher a gear when riding
  • toxic
    toxic
    yep as stated, just ride it normal, I ran mine up to 120 a few times but didn't travel for long periods at the one speed, mostly just normal road speeds.
  • hutch82
    hutch82
    Mate of mine says to progressively run up through the revs gently not just ring its neck but make sure to get revs up high a bit and alter speed often.....but he is a wanker so i usually ignore him and ring its neck a few times. Might not work but it is fun.
  • blubarb
    blubarb
    Thanks guys, that's some great advice. I seem to have done, and still am doing, a little of all of that so I am sure I have got it right. Some interesting stuff there.
