Baggers Rule
  • LOFTYBOB
    LOFTYBOB
  • gidgi
    gidgi
    update of my Roady
  • Steve L
    Steve L
    love the bigger front wheels, nice bike
  • gidgi
    gidgi
    thanks ppl ...Deadwood its a snap to do, fits straight on. Don`t know if yours is ABS or not but if so check they gave you the right bearing, I believe its supposed to be magnetic, not positive just what I was told..Although I told them I think they missed it & after I fitted the wheel myself , bloody ABS light on the  dash stayed on (which means its not operating ) Lucky for me Perth Harley fixed it no charge, all under warranty when I got my First service..
  • Deadwood
    Deadwood
    Looks good mate, I triple confirmed with DNA that it was set up for ABS.
    Will probably change it myself, how'd you go with the rotors, never done them, are they just bolt off bolt on?
  • gidgi
    gidgi
    yeah your right china, they are bloody tight!
    Sure do Lofty.
  • Deadwood
    Deadwood
    Appreciate the offer George. Reckon the bloke throwing the new tyre on might fit it gratis, muchos gracias.
  • Deadwood
    Deadwood
    Got my present delivered today...
  • Steve L
    Steve L
    cool, be good to see it mounted
  • moffycc
    moffycc
    looks sweet mate, whats the rubber goin on? and are ya leaving the forks as is or droping a bit to compensate the bigger wheel.be great to see the pic's when shes all done.
  • Steve L
    Steve L
    leave the forks as you will love the extra ground clearance
  • Deadwood
    Deadwood
    Cheers guys.
    Moff, only got 1 option with the rubber and that's a brand called Vee Rubber, only company that do a wide white wall in 21x3.5. Avon are bringing some out and there are a few Metzelers out there but are no longer in production at that size, so I'll go with the Vee and try and Avon after that.
    Going to leave the ride height at the front, only reports I've heard in the negative are about slow speed cornering i.e. parking, u turns etc. Reckon I'll get used to that.
  • gidgi
    gidgi
    love the black spokes nearly got them myself, agreed! leave the height its no big deal ..wantin to see those pics mate!
