Online: Neale, Trunksie
V&H big shots onto streetbob???
  • sparky89
    sparky89
    Hi guys,
    I'm looking at buying used V&H big shots, they were on a 2014 fat bob and I wanted to no if they will fit my 2014 street bob? From what I could gather on the website they will but just wanted to confirm. Thanks
  • Big Steve
    Big Steve
    They should fit if both have the big O2 sensors
  • Builder bob
    Builder bob
    Just made a set off an 06 with 18mm O2 sensors fit my 2013 fat bob. You just need the screw in adapters and maybe the extension lead. $50 from USA. You are most likely gonna be same size sensors so that part is not an issue. Are the brackets and fixing points the same. That's where you might have an issue. Sorry not much help
