How do I measure drive belt deflection on a ROCKER?
  • philthy
    philthy
    I'll open this subject up here as well. Adjusting my drive belt and manual says 11/16-3/4 in,my bikes jacked up,wheel raised. Where on a "ROCKER" do they measure to get that reading? The bloke at the bike shop yrs ago,grabbed the belt at the bottom,(Where the tension gauge is used,which I have) and said "if you cant twist the belt 90deg,its good" I thought that was a bit how ya goin!! I understand the tool and how it works,but exactly do I put a ruler. A "point A to point B" exact area is what I need. I can ring a shop,any fucking shop,tomorrow,but now would be cool....
  • bobby bob
    bobby bob
    iv'e allways used the 2 finger lift method on belts' don't know anyone who uses a tool like that, perhaps an American forum.
  • philthy
    philthy
    Yeah,know what you mean bob. I just would like to know how to do it "the book" way. Then after a while,just the 2 finger way will do.But until then,I wanna be sure. To be sure to be sure!!!! :)
  • robots
    robots
    hi,
    i got that tool philthy,very handy
    this what i found:
    Check your tension at the top of the belt on a Softail.
    There should be two O rings on the barrel of your tension gauge. Adjust the top one on the gauge to correspond with a reference point on the bike when the gauge is in position on the belt. Now set the bottom one the amount of deflection you want away from the top one. 3/8" should be about right. Push on the gauge on the belt so that the gauge moves from the top O ring to the bottom O ring in relation to the the reference point. When you have the belt tension to the point that the gauge moves from the top O ring to the bottom O ring with 10 lbs of pressure you are where you want to be.
    If this doesn't make sense, I will post a picture of what I am talking about. Let me know if you need it.
    Regards,
    Bill
  • rider
    rider
    midway between front and rear pulley, like as in figure 1 on the illistration you posted.
    not sure about yours, but some bikes have a little window in the lower belt guard that has gradient lines on it
    Any standard belt deflection is done at mid point between pullies.
