Online: Stuart
Exhaust System Valve ??
  • Fritzables
    Fritzables
    Hi All,
    I have just purchased a new 2014 Wide Glide which I will pick up from the Dealer on Tuesday.
    Whilst looking over it this morning, I had noticed that there is a cable operated Valve right where the Mufflers slip on.
    I understand what the valve is there for, but what are you lot doing with them??  Do we disable the control and have it Wide Open at all times ?
    Initially I will keep the stop pipes on until the bike is run-in then choose a suitable Exhaust and Air Filter, then start tuning.
    Pete
  • Damo222
    Damo222
    I had mine disabled after i put a set of slip ons on. The dealer tried to tell me i needed the fuel controller, etc, so i said see ya and had it done elsewhere.
  • Fritzables
    Fritzables
    Thanks Damo222,
    So, it's not just a matter of holding it Open with something....... It's a setting somewhere??
  • Jayman6
    Jayman6
    Don't quote me on it, but I'm pretty sure if you're running a TTS then you can set it to constantly stay open through the tuner interface. Hilly will know.
  • beagle
    beagle
    Just ask the dealer to have it disabled when doing the pre delivery service. Mine did.
  • Fritzables
    Fritzables
    Sounds like a plan Beagle.
    Do you loose much down low with it open at all times?
