Priming New Lifters
  • Independant_84
    Independant_84
    Great idea i have a brake vacuum brake bleeder here that attaches to the compressor i'll be giving this a try for sure.
    Interested to see how quiet they are on start up.
    When I installed mine, I primed the oil system until
    I had pressure, and they were still noisy as fuck for quite a while.
    Usually if I prime the oil system , the lifters are quiet on first start.
    I use soft jaws in the vice, but you could knock up some timber V blocks to fit.
  • Dutchy Hoogen
    Dutchy Hoogen
    I did not know about all that stuff. I used set length push rods. Just dropped all in. Cranked it few times with out spark plugs. Fired it up and sounded quieter than before right away. Hope I have not done something wrong.
  • Ando
    Ando
    So long a you let everything bleed down all is good
