Fork oil
  • Neale
    Neale
    Hi, I need to replace the fork oil on my bike, I have 70k on it and it's quite unpleasant to ride. Can anyone offer suggestions as to what weight/brand/amount to use. I'm 97 kilos and I'm aiming for comfort. Also, I don't have the cash for any u-beaut kit to install, just the oil. Any help appreciated......Neale.
  • ARD
    ARD
    ive used 20W in the past. works fine for me. 15 if u like it a bit softer. i generally use lucas oil, but any quality brand should do
  • Neale
    Neale
    Duuuhhh!!!!!, sorry people, dumb as dog shit !!!!
    08 Electra Glide Standard. ( that'd probably help).
    Just a hint that you probably know, to clean the forks properly, esp' if they haven't been done for a long time, you really should remove the forks and flush a few times
    with kerosene until clean, and leave upside down to drain overnight.
    You can just drain/fill them still fitted to the bike, but you will leave a lot of "gunge" behind.
  • Neale
    Neale
    Thanks for the tip, I'd have never thought of doing that.
    You will be shocked by the grey filth that comes out !
    If you want to be really thorough, you should also dismantle the forks and check the bushes for wear.
    Easy and cheap enough to replace.
    http://www.jpcycles.com/product/221-411
