Online: Retroman, John.R, Hilly
200 rear wheel conversion
  • Harris
    Harris
    hey guys,
           Thinking of converting my 150 rear wheel to a 200. Has anyone done this on a 72 sportster? how is the turning and what was the total cost fully installed. before and after pics would be awesome .
  • brash
    brash
    200 I'm pretty sure needs total new rear swingarm.
    180 can be done with a wheel swap and the right spacers
    170 can be done on the stock rear wheel, 170/70/16 shinko 777 etc
    http://www.hdforums.com/forum/sportster-models/847027-my-48-180-rear-conversion-pics.html
  • Harris
    Harris
    Hey mate ,
    Yeah happy to fork out for new swing arm ect, just chasing up info in total price for full conversion and if any major change in handling in corners ect . Wouldn't mind seeing if there would be any issues with going bigger than 200 .
    Cheers for your input btw.
  • GT 1200
    GT 1200
    I read you're going 240? So what's the story?
    New swingarm, fender... would you need to offset pulleys etc? How much (if you don't mind)
    Call Luke at Gworks, He builds his own Swing Arms, and can supply every thing you need 03 5277 9296
  • Harris
    Harris
    Thanks for all the info you supply Walka, really appreciate it. I unfortunately live in Sydney ,so the Melbourne shops are a bit out of reach.
    As i said Luke can supply the stuff to you, Dave and Mild & Wild in Preston is the right guy to fit it all
  • ANDYK
    ANDYK
    Gday Harris i,m curently doing the conversion at the moment ,as Walka said i gave Luke a ring ( good bloke to talk to very helpful ) you take your swngarm of and your front pulley send it to Gworks and they will modify them for you ,you will have to split your frame just under the seat and spread it a bit in order to fit the wider guard ,so theres a bit of home mods to do as well but no dramas,and the rim i just got through Walka at VPW another good bloke to talk to with a wealth of info ,i have,nt finished yet but when i do i will post before and after pics
    Gee i hope Luke throws in a free hoodie , Walka are there VPW hoodies available
  • Harris
    Harris
    cheers for that mate. You going the 200 ? I'm thinking maybe a 240 but not too sure if it wold look too big on the small frame . Did they give you a quote on what it's going to cost all up ? Pics would be great mate :)
    Harris .
  • spides666
    spides666
    Man 240 on a Sportster? Seen them on the Breakout and V Rod
    It is one of my lost loves with my Iron with that thin back wheel ; - (
