Online: Stuart
First time S/E tuner conection.
  • Dutchy Hoogen
    Dutchy Hoogen
    Hi everyone,
    Just hooked up my Screaming eagle tuner to my laptop for the first time. When I turn on the ignition I get the following.
    Super Tuner has determined that a new version of the VCI software is available.  Please reprogram your VCI with the latest update.You must update your VCI before continuing.
    It wont let me do anything else unless I click on ok. My fear is that if I do so it will alter settings or tuning. I have the 120r in the bike and it has different setting to the 103. I was told it was Dyno tuned at the dealer. Not sure if they did or I got an expensive download. From what I can see the file in there has my name on it.
    Please help.
  • EBT
    EBT
    Hi Dutchy,
    This process is a standard procedure. You can update your VCI without changing any settings and most importantly your tune. You wont reload a tune unless you tell it to in the reflash area.You can save the tune that is your VCI before you go any further so incase you do something wrong it will always be there for you to reload.
    With your tune having your name on it ??????? Download maps can be renamed in 10 seconds!!!!!  Custom maps take hours.
    Cheers Brian.
  • Dutchy Hoogen
    Dutchy Hoogen
    Brian I have since had a little play around. Was shitting myself though. Anyway what I have discovered is that the tune in my bike is identical to the down load. All the numbers and shading are the same as the download. So what I am asuming is that they only put it on the dyno to make sure it was not too far out and to give me a graph. I do feel misslead. But I guess not much I can do about it.
  • Daggs
    Daggs
    That particular dealership has a bit to answer for as far as tuning goes me thinks...
  • Dutchy Hoogen
    Dutchy Hoogen
    Maybe. Don't know enough to really point the finger. Not worth it any way. But I know if I was to get another bike I would buy the Tuner from Lushy and have him tune it too.
  • Dutchy Hoogen
    Dutchy Hoogen
    Hilly I will do exactly that once I have new pipe installed and saved the cash again.
  • Hunter
    Hunter
    G'day Daggs just wondering wot tuner u r using,I am running a S/E unit after having trouble with a thunder max unit.Thunder max was a good performer until it started to ping,after resetting a heep of times got talked into a S/E unit bike does not sound crisp & doesn't crack like it did.bike has been on dyno a couple times & runs 106 kit with 583 cams any ideas???
