import my bike
  • appolussa
    appolussa
    i need advice about bringing my bike over from new zealand, thanks in advance
    appol..
  • Retroman
    If it's your own bike , and you've owned it minimum 2 years , then it comes as a personal import. EASY BY COMPARISON
    Paperwork from Canberra , "Import approval" is required. Your bike looks like an Evo Springer ??
    The quiet ( AKA STOCK ) exhausts need to be on it , coming from NZ the headlight and speedo will be fine ( speedo has to be in K's )
    Then you get our Aussie equivalent of your NZ " Warrant of fitness" either from a Government station , or perhaps a local "roadworthy" workshop
    What state are you coming to ? may make a wee difference !
  • Retroman
    I brought "personal import" motorcycles from the UK ( Scotland) 19 years ago and it was not that hard
    I have helped Canadian dudes here in Perth on more than one ocasion get their personal imports licensed
    From memory if you have OWNED the bike for over 2 years the practice is fairly straightforward
    NOT THE SAME as going and buying a used 1990 and younger to bring to Aus as a current Aus resident
    All that RAWS compliancing shitola then comes into play . fuck i know i've been down that road and again helped many others
  • appolussa
    appolussa
    thanks again, ive tickled it up a bit with lumyer cam, adjustable pushrods. dynojets, s`n`s carb (40mil throat)  & strait hi low pipes.
  • rodrocket
    rodrocket
    Do yourself a favour, call Andy at Foytt's
    0423223912
    andy@foyttcompliance.com.au
    I used them for my V-Rod Destroyer & very happy with the service
    regards
    Rod
