2012 fat bob brakes
  • Telly
    Telly
    I have had this bike since new, the rear brakes are crap, the rear brakes on my 1989 softail are better, in january while riding around tassie, we called in to richardson's harlet davidson, i spoke to a guy in the service dept. and he agread with me and said they were crap' he suggusted i should try lyndal racing brakes, but i cant find any one in australia who sells them, any of you guys have any ideas ? the freight costs from america is ridiculous
    Telly
    Telly i run them with a fair few people including Gidgi recently installing them. They are available from Rollies Speed Shop in Brisbane who are a forum sponsor. Great people to deal with as well.
  • Telly
    Telly
    Hey, thanks for that, I'll give Rollies a call, this weather sucks, I've two bikes, cant ride either .....too cold
    Telly
    Your Fatbob has decent twin discs up front, I'm wondering why you need so much rear brake ?
    Your not an ex dirt bike rider ?
    Do they start off strong and then fade ?
    The rear brake is plenty strong enough from the factory, unless you have a fault somewhere, but it won't pull you up by itself.
  • Telly
    Telly
    Thanks for your comments, I've been riding for about 24 years and only Harleys, and while I agree the twin disks on the Fat Bob work o.k. , with heavy breaking you need to proportion at least 25% of your breaking to the rear wheel, well I do any way it's safe, not long after I got the fat bob, I reckoned the rear brakes were shit, so I took the bike back to the dealer(Peter Stephens Dandenong) they test rode it and said it was o.k. as far as I'm concerned they are crap! Especially when I compare them to my 1989 Custom Softail, so I have ordered a set of Lyndal Racing pads (gold) when they arrive and I fit them I'll report here and let you know the difference if any!
    Telly
  • Telly
    Telly
    I have put the new Lyndal pads in, They are better but not by much, but they are not bedded in yet, as Shingles says I'm going to go out and give the rear brakes a hard time. I spoke to our local Harley guy , says Harleys are built and designed for the yank market where they have long stretches of roads not windy stuff like we have, so the pads are hard so they don't wear out (they are crap) and there shockers are crap, (probably made in Mexico for $25!)
  • shingles
    shingles
    dont giv up on rears i was determined 2 either get sum sorta reaction outta rears i rode along with foot on brake at medium pressure then stabbed on then hard an repeated process zoomin along bit more pressure an keep constant 4 a few kays then release,let cool 4 a bit thewn stand on em in hard like panic stopp an this is only brake i hav theory ,now i thought rotor will either buckle or pads cook an brake oil b boiling but the oppisite had occured ,could stand on rears only at 100ks an get actuall feel of shit this is gettin better ,an continued my routine locking both front an rears then rears only ,now no new pads were bought or new oils jus checked feel at disc wen pedal applied an yes pistons were pushin pads an releaseing ,ive found ovr da yrs most rear brakes on all sorts of hydralic rears r prone 2 hav pistons siezed ive had 6 piston rears siezed an whole time u thinkin its da pads  ah no unbolt push pedal look bloody pads movin mil or so ,hummm get out aerosol lube spray around pistons o make sure pads out dont want oil on em then get g clamp i av small 2 large try windin in pistons with clamp some brakes r easy 2 work on sum aint i useally hav calliper in old bowl an old towel rags watever i wont bleed or go into pullin rite apart jus keep push pedal hard an movement may be small but now ill start windind clamp harder piston goin in ,hummm ok now i will inspect master cylindr all pressur off clamp an no pedal pressure remove cap dont touch brake pedal or clamp now u can see oil or sludge brown shit or maybe oil clean if so replace cap tighten an if pads av life well just repeat clamping pistons with tryin 2 wind in i put metal block over piston wen applyin clamp pressure ten try brake an if ya luky ya brakes will start actually working without avin 2 strip em down completely a lotta fukin around an ya wont av parts on hand 2 replace there is few other things now u can bleed an put new fluid in ,but dont attemt this unless u done b4 ,an av spar person that will do wat u tell them exactly wen bleedin ,but if ya brakes workin better than they were after a little in an out an fluid level is ok then that will get ya outta troub from feelin no brake 2 ah i can feel actually grippin disc i chek mine all time a short little lokup at lights ah yes ,rear brake does work an getts better i kid u not ,ah dem chrome aerosol things that r useless old coffe grinders with innings taken out ,now shoks ive looked yeah u can pay exuberant prices but there is australian company CALLED YSS SHOCKS manufactured here all rebuildable rite in ya backyard an will build 2 your spec even put back inside coffe grinder this company been doin over 25yrs 4 race teams all over world and has full range 2 fit every HD built an it not goin to break your mortgage payments prices start at 500 all garanteed rebuildable produt here u not havin 2 try an contact sum distributor in usa or werteever an get no response anyway an ya jus paid 2500 4 shit coz of some thing ya heard through grapevine from a bygone era wen da world was still flat ,i jus think da whole YSS SHOCK companyah ell a no brainer 4 me ,if fuks up or not doin wat ya said only phonecall away 2 sort all i need is da 500 i suppose i got it aw fuk me tyres rooted thats 300+, maybe i could take up rock rolling would be cheaper ,aw fuk can barly walk let alone chase after me rok wat a unit ive become ,but stay calm saz i SHINGLES
  • Telly
    Telly
    O.K. the weather is still crap, planning a three dayer over the grand final weekend (rather go riding than watch footy any day!), haven't really had the opportunity to work on my rear brakes, but so far have adjusted the pedal height to get a little more leverage, but I must say the Lyndal pads are better, and yes Shingles, my next job is to work on the shocks, the shocks on this bike are crap!
    Telly
  • Telly
    Telly
    Telly
  • shingles
    shingles
    dont av mates all gone an no cam butz i wantz 2 get 1 an reallshow some riding arreas used an things ,like u stated locking brakes an stuff mate ive ownened over 50 bikes and was on dirt everyweek doin enduro trials bike ive smashed an mangeled heaps we used 2 practice weelstnds on sat up this over k long gradiant gsx,s 1000 all that erea road was prfect4 this and dead end no traffic and u do mangle bikes a bit but ,mate runs motorbike shop but moral is our bunch of fella were into extreme on bikes an then on enduro bikes weekend guys n thisgroup had 2 be experienced as this is full on flatout as fast as u cango u will b slidin bike 90% of your ridin time my bike was WR360 husky 2 stroke as 2 stroke best les shit 2 fuk up in engine 2 many parts in dem 4 stroke motors an ya gotta drain oil every time ya use ut down go threw creek 2 deep or ya fuke 2 stroke attacts that shit with ease even if fall over roll over bike so wells take plug out put in higer gear an jus keep turnin bak weeel drain airbox and carbs leave few min bak over fill carbs plgive few kiks plug out should be able 2 smeel fuel at plug hole or put finre above an kik or pull kikstart lever in nuetral plug bak in an start kiking ,so skidding a ever had 2 lock up your bike compltely not jus hard braking ,if colloision imminnent and impact is goin 2 happen wat would u do lok ya brakes as hard as till brake traction also u should be ghangin down gogs or u just grabbed brakes hard as an wat u gunna drop it as a lot say ,i put her down well this can fuk u more ah its all about yrs of understanding phsiycs of machine an if your yryin to think about wat 2 do its gone past a point hat my body has reacted jus by sight alone of danger an its instinck an musclememory that has reacted already b 4 ya brain has decifered like say u goin around bend in rain bak end slips out big like ya goin down but usally my leg has already hit roadf 2 stop tyre slipin right out an down u go thats reaction an muscle thats made a decision b 4 u could even understand wat msg 2 send 2 limbs ,same here as ball comes outta nowere flyin at ya head an at last sec u will put hands 2 blok or move head this applies 2 most things in life ,i took new bike out test ride vl 1500 suz from springwood jus jumpedof me fzr 1000 exup now that fukin was missile ,anyway sayz to shop guy who comes with ya hopeu can keep up an took off flat out up m1 testin roll ons in diff gears waitin 4 shop guy fuk how fast u goin o hit 200 hang on were off again an startedburnout an hammered it in every gear then started givin big brake panic stops front only then combined an wen really brakin hard as will stand up wile doin so if bike wants 2 tuck under i av more ability 2 catch if loooks bad clutch in instantly then uve stopped that outa control motion my hands always restinnon clutch durin these test shop guy came alon i said watch this sped up papplied both brakes as hard as poss waiting then 120 she lockcs anperforms good as a bit over 2 right front wans go left jus ease off front a bit an that was no downghanges just fuk hit em so bak 2 yard a another burnout an more locks even at off ramp just kolok em both up an slide 2 lights jus 4 fun ,distance an wen to an all other questions ,well 43yrs of motorcycling an giffted rode bikes at exces speeds 4 yrs weelstands slidin around roundabouts wif rear spin all theses skilss dont jus hasppen or may 4 some and yes a lotta bikes get damaged in process thats how i can lock my bike at 120 think even masnage 160 lok once its controllable bike doesnt missbehave wen stars breakin loose at front i juslet little pressure  release turn bars slowly bak 2 centre back wll l be over 2 right a foot or so welokked buit doesnt try 2 spin u in 180 will remain in an controlable dead lokup slide ,its like do u no your crs behaviour in similar situations u can hav all da non slip abs bla bla i drive late model merc best brake ever had but cunt hits brakes half way acroosss major intersection an we both had booted 2 get threw fuk an is raining merc slid towards as of hiss car locked fuk new collision imminent let brakes off then turned weel hard right then left an applyin fuull brake again car still slid my friend now that reaction 2 take brake off turn weeel 2 miss fukwit happened aitomatically instnckly body new wat 2 do brain is in nuetral wile eyes an limbssortin out ,most people in same situation jus smash into car with foot hard on brake an push hard on weel an sit pushed bakinto seat in fear ,i hav taught myself these skills by repetivness not by luk an still got hit by car as came dirrectly across my path it fuked me 4 life but i stll ride took 5 yrs 2 walk with crutches 3yrs in bed 38 ops an still ride same ,well if i cant control bike if shit happen an domnt    know its controlability under worst oh o wreez fuked an look 4 sum sorta way out even leaning on car as training weels lift leg up 2 miss wreck an once past can pullover an give details a waks into car that can be used as training weels 2 get ya past smash have done this an worked u dont think o damages 2 dis an dat nah imlookin after me objects repaired or replayced ss ya SHINGLES I WANT MINI cam not gettin dum box that sits on top gunna gett small circullar device xreply they use on top fuel v8s wrally shit an well made an all bits in kit water proof billett machined piece lowndes uses drifters and on land speed lakes picture perfect plug in 2 telly 2 watch charges at wall or pc an all leads wif kit and has hours or recording not ten minremote can be on wrist like watch 2 big buttons on off but cant chek film unless u an ipad or lappy 2 c wat actually filmin so wen out u can go ah fuk an adjust without other device ah sleep on it jus bag em up get used 2 ya bige let it spinn dont bak off this is how i learn epwat bike does will it slideout at rear nah only foot or so an ill jus keep doin things like little weelies acosslites  usin clutch varyin grig threw clutch not ngine its alreay singin clutch is very inportant in this bike SHINGLES
  • 92Fatboy
    92Fatboy
    Sounds like you had some fun Shingles. Yes definitely worth recording a ride a or two for the grand kids later on.
