Online: Retroman, John.R, Hilly
New 48 Stage One Q
  • damoocow
    damoocow
    Have the money ready for a new 48 after selling my Buell. When I go to buy want to have the decision made about what  I want the air cleaner and pipes to be . Have decided that I want an oval shaped filter - SE do some nice ones - will go with one of those. Main problem I am having is deciding on a set of slip ons. I loved the sound of the microns I had on the Buell so have been scouring youtube clips listening to as many 48's as I can - hard to tell like that....I really am after something that looks like the US pipes - have always loved the baloney cut look, but has some good sound as well as performance. Internet searches are sending me batty - I found some pics for a Sonic slip on that has a baloney cut but can't find any info - are there any other pipes I should be looking at?? Last resort would be some SE or Vand H slip ons [straight shot style] but have my heart set on the baloney. Also all parts will be fitted at dealer prior to delivery so unsure if that makes a difference to what I can order.
    Any help appreciated.
    damo
  • Picker
    Picker
    Damo,
    I've just ordered a new 48, having it delivered late Sept... One thing worth thinking about is that if you wait a few more weeks, they are able to register the bikes as 2015 so will hold more value for resale.
    I've ordered mine with a heavy breather and V&H slip ons, black slash cut... They didn't seem to want to talk much about any other brand than V&H & SE... Must be some kind of deal they have going on. Would be interested to see how you get on though so post up when you've made your deal with them... :)
  • damoocow
    damoocow
    Thanks for the info Picker. What colour did you end up going with? I really loved the past orange colour but would assume you can't get an old colour in a new model?
    Did you already make a choice about what pipe style you wanted or did the dealer have info available to look at prior?
  • Picker
    Picker
    I've gone with Black tentatively... Will be popping into the dealer on Sept 1 when he has assured me he will have the new colour options available on his computer and I can make a final decision.
    I was concerned that the graphics etc may change as I don't mind the current 'FORTY EIGHT' on the tank but hated the previous 'Sportster' graphic if you know what I mean?
    I'm hoping that this year they have a new one which is better than the previous two as the iron graphic is pretty awesome.
    I went in and initially ordered it with the V&H slash cut short shots (as I like the way they look), but having seen the amount of shit people get on here for the noise of them & how many people have them, I decided slip ons would be the way to go so it's less of an ordeal if I have to do a noise test.
    Are you doing anything else to yours? Or just the pipes and breather for now? I gave the dealer a bit of a laundry list... Pipes, filter, tuner, bars, seat, springs etc...
  • damoocow
    damoocow
    Picker - just getting the basic stage one stuff for now, the other things I can think about as time goes by.
    So are you ordering a 2015 model that you get to choose the new colours?
    Jayman6 - you are a legend - the Rush and Khromeworks slip ons look the goods - did you buy one of those brands? - would you recommend? Dealer I went to was M and W as they are closest to me - they didn't really push any products, I was asking some Q as I hadn't decided what pipes to consider.
  • Jayman6
    Jayman6
    M & W in Brisbane? Just speak to Luke. He'll sort you out, a good bloke. I contemplated the Rush's, but went with a 2-1 system in the end. My original intention to buy a sportster evolved into a fatbob.
  • damoocow
    damoocow
    Yep Brisbane - forgot to add that...So Luke is on the parts desk? - thanks for that, this is all starting to make some sense .
  • AK47
    AK47
    Please find below...it might help.
    Not my work...just copied from another forum.
    HD Screaming Eagle
    -Street Canon Slip On http://www.harley-davidson.com/store...06-64900209--1
    Vance & Hines
    -Short Shots http://www.vanceandhines.com/store/s...llsystem/47229
    -Strait Shot Slip On http://www.vanceandhines.com/store/s.../slipons/16863
    -Twin Slash Slip On http://www.vanceandhines.com/store/s.../slipons/46861
    D&D
    -Bob Cat 2-1 http://www.danddexhaust.com/catalog/...dson/sportster
    -Slip Ons http://www.danddexhaust.com/content/...-slip-mufflers
    Akrapovic
    -Slip On http://www.akrapovic.com/#!/motorcyc...64&yearId=2482
    -Open Line http://www.akrapovic.com/#!/motorcyc...52&yearId=2417
    Bassani
    -B1 2-1 http://www.bassani.com/part/1X38RB
    -Black Sweeper http://www.bassani.com/part/1X2FB
    -3" Slip On http://www.bassani.com/part/1X27SB
    S&S
    - Slip Ons Tapered/Slashed/ http://www.sscycle.com/product/Sportster/Exhaust-c33/
    Rush Racing
    - Slip Ons Baloney/Slash Down http://www.rushracingproducts.com/sportster2014.html
    If there are any that I missed or you want to add to this list just post them up for future use
  • damoocow
    damoocow
    Thanks for that, very helpful.
