air filter options 58 mm throttlebody
  • timsporster
    timsporster
    gday all just thought i would ask for some advice for an air filter to suit the 58mm throttle body on my 120r dyna
    its got a screamin eagle setup on it at the moment which is the one straight off the throttle body not the heavy breather 90 degree one
    had a look around the net and dont mind the arlen ness setup
    whats everyone else using with the big TBs??
  • robots
    robots
    Hi,
    Same as you, does the job well
    Thanks
    Robots
