Online: Merv
Bike Lift from Supacheap Auto
  • Broke
    Broke
    Supacheap have a special on a bike lift. Has anyone bought one ? Are they okay ?
    It will lft up to 680 kgs apparently.
    [product image]
  • Bucky15
    Bucky15
    Broke I've got one of the orange pro lifts, 680kgs also. Works a treat and easy to use by yourself. I have a F'Boy and have no worries getting it on and off. I think it came from Repco though.
    Lots of people here own them. Some need to mod the lift slightly depending on the bike.
  • Broke
    Broke
    Thanks guys. I need to start doing maintenance on the bike (sportster) myself and thought this would help.
  • Hallze
    Hallze
    I've got one of these. It lifts my street glide no worries. Its a good bit of gear for the price.
    no matter what lift you buy its worth buying the genuine Harley orange lift mount kit protects the frame and lifts a touch higher
    and does feel a bit more stable when used
  • Independant_84
    Independant_84
    When are they on sale at supercheap i went and had a look at the latest catalogue and coudln't find them..
  • Broke
    Broke
    It was in a catalogue that was in the letter box, but it has gone out with the rubbish. I cant see it online either (Perth location). It said reduceded from $!89 to $129
  • Bucky15
    Bucky15
    Repco currently have them on sale for $129.00 (save $89.) until 10 Aug.  It is the same as I have. Good deal.
  • steelo
    steelo
    Check the width and depth of the rubber rails. Get one that's too narrow and its a chore to line it up under the bike. A friend bought one for his vulcan and those little welded bits on the ends caused grief + the rails were too short. See the other thread on bike lifts. The blue one I got from Burson auto was slightly more expensive but built bigger. Cant beat the $130 price tag though.
    Look here
    http://www.hdforums.com.au/Default.aspx?tabid=71&forumid=37&tpage=2&view=Topic&postid=477885
  • Independant_84
    Independant_84
    Thanks will check them out at repco in the morning.
  • Harry28
    Harry28
    They're probably all made in the same factory in china and painted whatever. If ya can't get one there give ebay or the net a go. I'm sure I paid 120 for my red one but picked it up near home. works good on dynas and sporties.
  • Captain Hook
    Captain Hook
    Had one for years, looks very simular to the one in the picture and its great.
    Mine has a safety ratchet (with more graduations and on both sides different to one in picture) which is handy because my jack very slowly creeps and I also don't trust a jack on its own with 300 kgs of bike on it. It might not fit under there if your bike is lowered, mine only just goes under when its on the sidestand and its not lowered. The rubber strips on it so paint on frame is not scratched, little metal ridges on the ends of the lifting flats are good to have so it doesn't slide off, cos the bike is on the sidestand when you slide it in and start lifting, the jack has to be able to roll freely on the floor as it gets jacked up. As someone else wrote check the lifting flats are long enough to span the frame rails. Also check the clearance and fit to the exhaust as it is jacked up, some might be lower than the frame rails, or you might have a performance enhancing, exhaust reverse pulse cancelling, reverberation power bump fitted for free, lol.
  • PaulT
    PaulT
    I bought one of those SCA bike lifts and took it back, I bought one from Repco for about the same price. The SCA lift didn't lower the bike nice and slow but just dropped it no matter how much you feathered the down pedal. The repco lift is far better quality and lowers the bike nice and slow. That's my experience anyway :o)
  • Independant_84
    Independant_84
    I picked up the repco one on sunday it has the safety ratchet and works well fits under the bike with no issues .
    I did notice the jack does slowly come down on it's own though.
  • Captain Hook
    Captain Hook
    When you get a Harley, lifting the bike up and pushing a milk crate under it just doesn't work any more.
  • Jimmy The Human
    Jimmy The Human
    I got one and it lifts the Softail no worries although I woud'nt go hanging of spanners and giving things a good jerk if you get my drift,,,it would not lift the Mrs Yammy 650 the frame is to wide...
    cheers Jimmy
  • FXDF12
    FXDF12
    Got the Repco Prolift today it was missing a couple of bolts other than that it looks pretty good and should do the job nicely.
