Fork seals on 2007 dyna streetbob
  • Streetbob06
    Streetbob06
    Hi all,can any one tell me how hard it is to change front fork seals on a 2007 streetbob? Any tricks to this ?thanks
  • bobby bob
    bobby bob
    you will need a manual.
    only visit this site every few days so sorry about delay.
    I have uploaded two manuals to Dropbox to give you the options. You should receive email after midday...
    A) DYNA MANUAL - this has 46 files, totalling 43.4 MB and is the manual I purchased on DVD. Easiest way to access is to open by selecting the file MAINTOC.PDF and then navigate the section you want.
    B) This is just a PDF file "2007_Dyna_Service_Repair_Manual.PDF" that I think I downloaded from the net... It is 85Mb and just straight PDF that is more difficult to navigate..
    Have fun
    UH
  • Daggs
    Daggs
    Might be a good opportunity to fit progressives new drop in cartridges, no more leaking seals and their adjustable preload would be good. I'll be fitting some after I get back from the states
