Online: beaglebasher
1999FXD Superglide
  • Flying kokonut
    Flying kokonut
    My superglide has started blowing out oil from the breather pipe on the left side of the transmission cover. It's not a lot but its starting to oil up my rear tyre while I'm riding. I've checked the external oil line and its not blocked. Any ideas what may be causing it?
  • Koala77
    Koala77
    When I rebuilt my motor I had noticed the timed breather assembly bore was worn, the plastic breather drum chews out the cast bore, it's not a major problem and I could have fixed it for $100 when motor was apart, you can hone the breather bore and buy an over sized breather drum!
    You may even have a clogged filter, take ya filter off, drain oil in line to filter( if any) replace filter and see how it goes!
