Online: beaglebasher
Aftermarket shocks
  • FatboyGooch
    FatboyGooch
    Hello could someone recommend some aftermarket shocks for my 04 FLSTF Fatboy and a dealer would be fantastic cheers
  • FatboyGooch
    FatboyGooch
    Hello berms the way it set up now is useless really tight I weigh 70kg  and ride 2 - up a lot  the country roads done my way are bad .The bike had a lowering kit in it when i brought  The bike done 24000klm thought it would be easy to just replace shocks
  • FatboyGooch
    FatboyGooch
    Thanks Koala thats the advice i wanted to here I brought that spanner but did not get the concept how it work just used a spanner to adjust  nuts to bring mudguard up higher which still made things tight     Which way will I turn the shock canister towards the back wheel or towards the front to get a less firmer ride ? Thanks
  • FatboyGooch
    FatboyGooch
    Cheers thanks berms sounds easy enough. I am now interested to now were its set at I let you now how i get on ,job for the weekend  thanks
