Online: beaglebasher
R/H turn signal stays on
  • kinl
    kinl
    Hi guys,got a bit of a strange one here.R/H turn signal stays on when the ignition is on.Engine starts and bike rides.All 4 indicators flash when hazzrds on.Still on when TSM removedand speedo disconnected.Not switch as have removed.No obvious signs of a short anywhere.Any help would be apprecited.Cheers...KINL
  • gidgi
    gidgi
    check ya fault codes , there`s a post been done on here many times how to ...search fault codes in the appropriate box on home page.when you do your bike it will give you a number then match up with corresponding area ( ie problem)
    Yeah, check the fault codes. I would have thought buggered bulb, but if the hazards work.... What were you doing (mechanical work wise) when it started? Maybe a fucked relay?
  • kinl
    kinl
    Thanks guys...first thing I did was check the fault codes and zilch.Will just go through everything again methodicaly.
