Online: Stuart
Dyna Street Bob
  • smolly
    smolly
    Hey guys,
    Looking at buying a Dyna Street Bob,
    preferably 'denim black' what's has anyone got for sale???
  • gidgi
    gidgi
    Bike point, gumtree! my first bike was a street bob loved it, wish I still had it
    And eBay and watch the for sale forums.
  • Big Steve
    Big Steve
    The used market for Streetbobs is loaded you can get pretty much any colour, any mods, any kms and any price.
  • smolly
    smolly
    Yeah I've looked everywhere, Ebay, bikesales, trading post, gumtree.... Just thought someone on here might be getting rid of one..
    Streetbobs don't seem to be going any cheaper (relative to purchase price) than any other Harley. In fact I think the prices have risen over the last year since new imports aren't such a huge issue. Maybe I've looked at the wrong time, or you've looked at the right time...
  • peterjs
    peterjs
    hi i have 07 streetbob,14,000 on clock,just fitted new shinko777 whitewall tyres,new high flow 4in k n air cleaner,vance n hines big shot staggers exhaust , raked front end,16in black apes internal wired,forward controls,custom spring seat,leather tool bag on battery box,progressive rear shocks,detractable sissybar an more,insured with shannons,$18,000.asking $17,000 firm,rides great,peter 0478162692 melbourne
  • Blackbob
    Blackbob
    i got a blackbob but it aint for sale cool
  • bignuts
    bignuts
    any one of the street bob owner have any vibration problems ?
    i have a fatbor and the wife a street bob and has terrible vibrations, had a buggered front engine mount so this was replaced under warranty , but still no better.
    Mine vibrates a bit, but nothing that worries me. It is meant too, since the force from a vibrating engine has to somewhere and that's what rubber mounts are for.
    If it's really bad you can put the bike upright (use a brick or wood under the stand and having a person there to hold the bike just in case helps) then use a jack under the engine to take it's. weight. Then remove the bolts from the front rubber mount, add few washers between the rubber and the frame, replace the bolts and you'll find it vibrates way less. Don't go fucking nuts with the washers because, like I said, it's meant to vibrate.
  • Daggs
    Daggs
    No bad vibrations on mine, before or after I fitted the stabilizers
  • Blackbob
    Blackbob
    There is a top mount under the tank that have been known to come loose on these dynas
    Try a Sputhe positrack that will do wonders for the handling of your Dyna and will strengthen your mounts
