Online: beaglebasher
Cleaning Screaming Eagle air filter
  • Denoz
    Denoz
    How do you clean a Screaming Eagle pod air filter correctly? Wash with warm soapy water let dry and then a fine coat of air filter oil? The service manual has only how to clean the "standard" air filter. (warm soapy water, dry, "NO" oil) I Have been told to use air filter oil on the Screaming Eagle pod air filters. If this is correct will the warm soapy water be enough to clean the filter or would you use a air filter cleaner?
  • FXST11
    FXST11
    K & N make a kit to clean the Pod ( oil based ) air filters.
    If unsure just google what you want., OR  copy & paste the links below into the window at top of page
    https://www.youtube.com/watch?v=jPb4XpiKIk4
    http://www.knfilters.com/cleaning.htm
    http://www.supercheapauto.com.au/online-store/products/K-N-Air-Filter-Cleaner-KN99-0606-355mL.aspx?pid=154618#Cross
  • markwoumla
    markwoumla
    FXST11 has put you on the right track.
    I clean and re-oil my air filter at 5000 km , (when I change my engine oil ), may be overkill, but I'm in the mood.
    Just make sure when you rinse the degreaser off ,(tap water pressure , and rinse inside out ).
    And when you re-oil, (spray), don't over do it, just get a red tinge over the entire filter and let it fully dry before install. Cheers.
  • Nomada
    Nomada
    Check out youtube as well.
    Heaps of how to's on Harleys.
    Do my own services now thanks to the effort others.
  • Denoz
    Denoz
    Cheers guys. I'll look into that.
