Late model Dynas with the bigger tank
  • Big Steve
    Big Steve
    Hi All,
    Looking around the place I can see that of the late model Dynas (say anything TC96 or newer)
    • The Street Bob, Lowrider, Switchback and the Wideglide all have the slightly smaller tank - 4.7 gallon.
    • The Fatbob have larger tanks - 5.0 gallon
    But the Superglides seem to be a mixed back of 4.7's and 5's depending on where you look for stats across various model years..
    Can anyone confirm/elaborate?
    Steve
  • pat
    pat
    Fxdc super glide custom Fxdf  and 06-08 fxdwg have the big fat tank and big single speedo guage
  • robots
    robots
    Hi,
    Check the service manual sparra as it groups similar components together like dash, tank etc ie. fxdf and fxdwg be this one and fxdc and fxdb this one
    Looks like fxdb, fxdl and fxdwg same, fxdf and fxdc same, fxd on its own
    you would think all bolts on same just dash and componetry different
    Thanks
    Robots
  • pat
    pat
    Probably are but how easy is the question, then how much. Then there is clearance of trees and indicators
    Guys on here have changed tanks on other dyna models,
    Some one some where my have done, will google
