street bob starting issues
  • carl65
    carl65
    Hi All
    wondering if anyone else has this problem
    short ride to servo, after fueling, the motor cranked over for a few time then backfired after that started fine
    rode for about 45 mins, turned off for about 5 mins and had the same thing happen
    bike is a stock 2011 street bob any ideas or advice would be great thanks
  • Big Steve
    Big Steve
    Mine does it from time to time, I usually put it down to fuel.
  • timsporster
    timsporster
    pull your batter cover off and check the battery terminals, the neg one comes loose and causes probs
    difficult to know if it's the same, but I've had issue on my 2007 Street Bob since near new. Been told it's starter clutch, but I'm not sure. Most of the time I hit the starter as soon as I turn the ignition and seems to solve most of the problems.
  • sponge90
    sponge90
    mine stopped doing it when i took the stock battery out, mind you my stock battery may have been a lemon..
    fuckin thing would go flat every 3 days.. not ideal when working 6/6
