Spongey front Nissin calipers.
  • Phillthy
    Phillthy
    How many of you have spongey front nissin calipers?
    I found a way to get some lever back on them. Just push the caliper to re seat your seals on the pistons and pump the lever back up.
    The best way is to grip the disk with your finger tips and put the ball of your hand on the caliper and squeeze the caliper to the disk (not to far as you are only squaring up the seal and not putting in new pads). This will force the pads apart and square the seal up against the piston. Then just pump your lever back up (will take a few pumps) and you should have a firmer lever and much better front brakes. Just watch your first stop as you would be used to a crap lever and will not have to use so much lever.
    You may have to do it twice but will give you a much better stopping bike. Well it does for me anyway.
    Good luck with it. Cheers Phillthy
  • kingchops
    kingchops
    Phillthy,
    I gave this a go today and it works, good tip, very easy as well.
  • Phillthy
    Phillthy
    Yeh, think I will put some pics here later showing how to do. Nice, simple, easy and great result.
    Glad was able to do for Jilli the day before. Gave her time to get use to the better lever.
    Just have to watch the brakes for the first few goes to get used to the less travel and better braking power.
    Good luck to all that give it a go.
    Cheers Phillthy
  • Phillthy
    Phillthy
    Has anyone tried this?
